One 1721, one primary connection and how to configure the backup one
Jun 15th, 2007
HI,
I have a 1721 with two wics.. 1wic 4 lan port and the other one is a 1wic adsl.
Both stablish vpn to the same public ip.
Now, default static route is behind the first connection, but if it crashes?
how can I configure the router to route the packect from the first line to the second one if the first fails?
best regars
jarvar832004 Fri, 06/15/2007 - 02:24
If your question is how the second preferred routing is to be done , then use a higher matric towards the ATM interface for the ADSL link. If your question is how to detect the ethernet going down , that will be either by a routing protocol or by tracking some reachable ip which when unreachable the secondary route will be used.
edgar-quintana Fri, 06/15/2007 - 04:19
The router has this configuration:
ip route 0.0.0.0 0.0.0.0 publicIP permanent
The solution will be:
ip route 0.0.0.0 0.0.0.0 publicIP permanent metric 1
metric 2
