callmanager 5.X : does anyone know the difference between an application
Answered Question
Jun 15th, 2007
callmanager 5.X : does anyone know the difference between an application user and an end user ?
Many Thanks
Dirk
Correct Answer by mchandak about 9 years 8 months ago
An Application User is normally used when you need a account for another application, like Unity, IPCC, 3rd Party softwares to connect to CallManager.
End User, is used for IP Phone users, which is the same as the previous versions.
Check the following link for more information about the user of either of the users.
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_administration_guide_chapter09186a008037e2d2.html#wp1028203
Overall Rating: 5 (1 ratings)
Correct Answer
mchandak Fri, 06/15/2007 - 03:20
