Lossing network resources when connected to Cisco VPN
chrisjohnston
When I connect to a PC, via CISCO VPN, I appear to loss access to;
a) my network drives
b) Internet connection.
Is this standard for CISCO VPN Connection?
Is there a way to configure it so that I can still get access to the network drive at my end?
insbannis_j
Been a while since I worked on VPN's but from memory you have two options
1.enable split tunneling
2.Use Local LAN access setting on the VPN Client.
Not sure of the platforms you are running however after a quick search the following links may provide you some direction.
VPN to Concentrator Split Tunneling
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a00806f34fa.shtml
VPN to Concentrator Local LAN Access
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a00806f34e6.shtml
Hope this helps and is what you meant by "connect to a PC, via CISCO VPN"
Good Luck,
Justin
