archives and log files.
Answered Question
Jun 15th, 2007
System as follows:
win 2003
1. CiscoWorks Common Services 3.0.4
2. Campus Manager 4.0.4
3. CiscoView 6.1.4 19
4. Device Fault Manager 2.0.4
5. Internetwork Performance Monitor 2.6.0
6. Integration Utility 1.6.0
7. Resource Manager Essentials 4.0.4
I am looking to move all repositorys to a separate drive on the server.
I have moved all the log files by following the following procedure: (may be useful)
net stop crmdmgtd
C:\>cd\Program Files\CSCOpx\cgi-bin\admin
C:\Program Files\CSCOpx\cgi-bin\admin>perl logBackup.pl -force -dir D:\Program Files\Logfiles
Verify the procedure was successful by examining the contents of the log files in this location C:\Program Files\CSCOpx\log\*.log.
net start crmdmgtd
this has worked a treat allthough the walkthrough was for a different version.
*Question - What files can be moved - images/backups etc and how.
If you can answer any or all it would be very helpfull and probably save me some time over the next couple of days.
Thanks for reading
ben
Correct Answer by David Stanford about 9 years 7 months ago
You can also change the archive location for your configs:
RME - Admin - Config Mgmt - Archive Settings and specify the new location here
You can also specify a different location to place the LMS backups in as well:
Common Services - Server - Admin - Backup
Software Images can also be moved:
RME - Admin - Software Mgmt - View/Edit Preferences
Overall Rating: 5 (2 ratings)
Correct Answer
David Stanford Fri, 06/15/2007 - 05:51
