Logging Callmanger 5.1 Configuration changes.
Jun 15th, 2007
Hi, is there a method (log file) to tell when a certain change was made to a Call forward on a phone within Callmanger 5.1. Firstly I am after looking at when config changes were made and secondly (if possible) by which MLA account.
Thanks in advance!
Regards Mark
wrightmp Tue, 06/19/2007 - 01:39
Are you aware whether there any specific logs that ref the admin page changes made?
I am not aware of these, but there are many logs you can turn on. There are some enabled by default and others are not. Do you know where to check?
in CCM > Application > Cisco CallManager Serviceability
In Cisco Callmanager Serviceability > Trace > Configuration > pick the server or servers from the list on the left pane > click the type of info you want. I picked Cisco Call Manager > and then you can select what Trace you want.
wrightmp Tue, 06/19/2007 - 22:49
Thanks for your reply, yes I was aware of these logs, but not that they contained details of CM config changes.So now I am after the methods of how to extract this information from these logs.
Kind Regards Mark
