Avaya Interchange - VPIM
Answered Question
Jun 15th, 2007
  • Blue, 1500 points or more
I have integrated to Avaya Interchage via the Unity Bridge - http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_feature_guide_chapter09186a008045e21d.html
However, I would rather just use Unity and VPIM.
Documentation on Avaya Interchange says it supports VPIM. However, Avaya has told me they require a "Message Networking Box" to integrate via VPIM but that doesn't make sense.
Anyone able to comment on if we can integate Unity to Avaya Interchange via VPIM without needing the Unity Bridge?
Correct Answer by thisisshanky about 9 years 10 months ago
Andy, Did a similar integration and Interchange doesnt support VPIM v2 standard. So the client had to upgrade that to Avaya Message networking manager which is the newer product and supercedes Interchange. AMN manager can still integrate with other Avaya Intuity voicemail systems and run VPIM to Unity. You dont need a bridge to to this.
Sankar
Overall Rating: 4.5 (2 ratings)
ranpierce Fri, 06/15/2007 - 06:30
  • Silver, 250 points or more
There is no way you are going to get away from using a bridge unity you have a full Unity network. The Bridge server is seen on the Avaya Interchange network as a Avaya Interchange Node. It does not matter to Unity what protocal they are talking. VPIM is one that is supported.
Unity will not be able to be a node on the Avaya Interchage Network without a Bridge server to my understanding.
rlp
Correct Answer
thisisshanky Fri, 06/15/2007 - 07:33
  • Purple, 4500 points or more
Sankar
