06-15-2007 06:33 AM
What is the best procedure to reduce downtimes to upgrade 2 ASA5520 in failover from 7.0.2 to 7.2.2 and to change their activation keys to allow more contextes ?
From what I read, to have no downtime for the software upgrade, we should go from 7.0 to 7.1 then to 7.2
But for the activation key, I only found a procedure for PIX, not for ASA, which gives a few mins downtime.
Is there a way to upgrade the activation keys on a ASA pair without downtime ?
(because if there is a downtime, then we'll upgrade directly from 7.0 to 7.2 and change the activation key at the same time)
Thanks in advance for your output,
Karim
Edit: sorry, just saw I posted in wrong place but don't know how to move it
06-20-2007 09:33 PM
HI Karim,
Check this link for more details :
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_7_2/conf_gd/sysadmin/mswlicfg.htm
Raj
06-20-2007 11:55 PM
Hi Raj
Thank you for answering.
I already found this doc, however the thing it doesn't say, is what the best method to upgrade *the activation keys* on a failover pairs to reduce downtime. (it speaks on how upgrade the image)
I only found an older doc about PIX'
regards,
Karim
