06-15-2007 06:36 AM - edited 03-11-2019 03:30 AM
Seeing the problem described by this old post to NetPro (which has no resolution)...anybody recall or know the resolution?
I have got a ASA 5510 running 7.2.1.
The outside interface recieves the IP address over pppoe. Normaly you don't need to configure a fix IP with pppoe, but for any reason I don't recieve an IP address until I hardcode it on the ASA. Then when I reboot the ASA the IP address of the outside interface is lost.Further, I'm not able to change the subnetmask, it changes always to a host subnetmask. Has someone already made the same experience? See below the configuration of the outside interface and the pppoe statements.
interface Ethernet0/0
nameif outside
security-level 0
pppoe client vpdn group any
ip address XXX.XXX.XXX.XXX 255.255.255.255 pppoe setroute
vpdn group any request dialout pppoe
vpdn group any localname username@switzerland.net
vpdn group any ppp authentication chap
vpdn username username@switzerland.net password ***** store-local
Best regards
Peter
Show All Messages | E-Mail this Message
Did you configure the ip address to... by cpembleton - Jul 10, 2006, 5:34am PST
Hi Chad, yes I tried it, but I neve... by pwenger - Jul 10, 2006, 6:05am PST
Hi Chad, Sorry to ask the obvious, ... by glen.messenger - Jul 10, 2006, 6:18am PST
Hi Glen I figured out now the bug. ... by pwenger - Jul 11, 2006, 4:49am PST
Posted by: pwenger - System Engineer, CASSARIUS AG - Jul 11, 2006, 4:49am PST
Hi Glen
I figured out now the bug. When I enter the IP address at the outside interface with for example a /30 subnetmask, it takes this command, but for any reason it changes the mask to /32 when you have a look in the running config a few seconds after you entered the command.
See this below:
ciscoasa(config-if)# ip address 213.200.233.189 255.255.255.252 pppoe setroutPPPoE is already enabled on outside interface - now clearing
ciscoasa(config-if)# sh int e0/0
Interface Ethernet0/0 "outside", is up, line protocol is up
Hardware is i82546GB rev03, BW 100 Mbps
Auto-Duplex(Full-duplex), Auto-Speed(100 Mbps)
MAC address 0012.d949.147e, MTU 1500
IP address unassigned
58 packets input, 4483 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 L2 decode drops
61 packets output, 4678 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (1/0) software (0/0)
output queue (curr/max blocks): hardware (0/3) software (0/0)
Traffic Statistics for "outside":
91 packets input, 5419 bytes
61 packets output, 2973 bytes
0 packets dropped
1 minute input rate 1 pkts/sec, 64 bytes/sec
1 minute output rate 0 pkts/sec, 34 bytes/sec
1 minute drop rate, 0 pkts/sec
5 minute input rate 0 pkts/sec, 0 bytes/sec
5 minute output rate 0 pkts/sec, 0 bytes/sec
5 minute drop rate, 0 pkts/sec
ciscoasa(config-if)# sh run int e0/0
nameif outside
security-level 0
ip address 213.200.233.189 255.255.255.252 pppoe setroute
nameif outside
security-level 0
ip address 213.200.233.189 255.255.255.255 pppoe setroute
Then when you reboot you get the following message:
ERROR: Bad mask 255.255.255.255 for address 213.200.233.189
*** Output from config line 16, " ip address 213.200.233...."
and for this message there is no IP anymore on the outside interface.
06-17-2007 07:42 AM
Do you have a static IP address assigned to your from you ISP? Post your specific scrubbed config.
