CSA: Report Export/Printing Limits
Jun 15th, 2007
Hello, I was wondering if anybody has run into any export limits with regards to the CSA reports. I.E. how many events/size can the reports be in order to export them. I know with the excel export there is a limit of about 16365 lines (or about 8150 events).
PAUL TRIVINO Fri, 06/15/2007 - 08:38
I believe the 16K limit is Excel. Try exporting to csv and opening the file with Notepad or Access or something.
Paul
wyley.johnson Fri, 06/15/2007 - 08:42
Thanks, but I am aware of that limitation. I am concerned about the other formats. Has anybody come across limitations for those?
Or for printing via PDF? Are there limitations to how many pages it will convert to PDF?
tsteger1 Fri, 06/15/2007 - 10:33
You don't mention the version but 5.2 is limited to 12500 events. You could get more with a DB query.
Tom
