06-15-2007 07:09 AM - edited 07-03-2021 02:13 PM
Hi All,
I've upgraded WLSE to WCS using the CD's supplied by Cisco, and that all went swimmingly, however they supplied WCS v4.0, and I need to run v4.1. So, I've downloaded the 4.1.83.0 bin file, and burnt it to CD, and have also uninstalled the old version of WCS Successfully, but when I come to install the new version of WCS, it all starts to go wrong!
1. log in to the CLI as root
2. mount /dev/cdrom /media/cdrom
3. cd /media/cdrom
4. ls (show the correct file name)
5. enter "./WCS-STANDARD-K9-4.1.83.0.bin"
and then I'm presented with an "Input Output Error", and subsequently am unable to install the new version of WCS.
I've tried the usual things like rebooting the box, mounting /dev/cdrom to a different directory, etc... but I always get the same error message.
I've looked through as many Cisco docs as i can find, but not been able to find anything about troubleshooting the installation process... Any help, much appreciated!
Thanks all..
Solved! Go to Solution.
06-15-2007 08:22 AM
Try this:
mount the cd
cp WCS-STANDARD-K9-4.1.83.0.bin /tmp;
chmod a+x WCS-STANDARD-K9-4.1.83.0.bin;
cd /tmp;
06-15-2007 08:22 AM
Try this:
mount the cd
cd /tmp;
06-19-2007 04:34 AM
Hi Eric,
I thought this very helpful info surely deserved my 5 points. Keep up the great work here! You have added some fine insight to these discussions.
Take care,
Rob
06-19-2007 05:16 AM
Thanks!
