IPCC Agent Login - CCM Publisher Failure
Jun 15th, 2007
IPCC v4.5
CCM v4.1(3)
Guys,
I am using the CCM Publisher & Subscriber design with IPCC v4.5 on aseperate server. We recently had a failure on the Publisher and although logged in agents remained active and the CTI Service flipped over to the subscriber any subsequent agents were not able to login. Do you know if this is normal operation within this design or should an agent be able to login with the Publisher failed?
Overall Rating: 2.7 (3 ratings)
Chris Deren Fri, 06/15/2007 - 09:06
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
First if all IPCC Express 4.5 is not supported with CM 4.1.
Are you sure that's what you have? Maybe it's IPCCX 4.0 or CM 5.X?
Make sure that under your jtapi subsystem all CTI servers are listed.
HTH, please rate all posts!
Chris
cmcinally Sat, 06/16/2007 - 05:08
Apologies the IPCC Express version is 4.0(4) and the CCM Version is 4.1(3). Should an agent be able to login if the publisher is down? Does the agent login process require write access to the database. I went through extensive testing at the time of installation but did not test this particular function, The CTI Failover etc is all fine.
lpezj Sat, 06/16/2007 - 07:43
  • Gold, 750 points or more
Have you check in the IPCC Express AppAdmin web pages if you have added the two CallManagers in the JTAPI provider, the RmCm provider and in the Directory configuration?
Both CallManagers must have the CTI manager service up and running.
Hope this helps,
Juan Luis
mmelbourne Sat, 06/16/2007 - 15:27
  • Silver, 250 points or more
Do your agents use Extension Mobility? If so, this won't work if the Publisher is offline; another consideration in failure scenarios.
The Cisco Desktop Administrator Configuration Setup also has configuration settings relating to available CallManager servers, and this was populated with only the Publisher (we have a Subscriber). The documentation doesn't say what it's used for.
cmcinally Sun, 06/17/2007 - 08:00
We dont use extension mobility but thanks for the tip. I will check out the Desktop Administrator Configuration and let you know. The funny thing is that agents who were logged in were fine but any other agents trying to log in whilst the publisher was down.
