Remove 2nd Exchange Cluster from Unity
Jun 15th, 2007
Unity 4.2.1, Exchange 2000
I have two Exchange 2000 clusters serving up our VM system. I would like to remove one. I have verified that the cluster I want to remove is not the Partner Exchange Server. What do I need to do to remove the second cluster? Thanks
sopayne Mon, 06/25/2007 - 11:49
  • Cisco Employee,
Hi Beth,
Since without clustering Unity is partnered with only one server and when using clustering, Unity is partnered with one virtual server, as long as Unity recognizes the correct virtual server and doesn't need to access mailboxes in the cluster you want to remove, there should be no action necessary on the Unity server itself.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/unity40/inst/inst405/5ue2k3nf/ig_018.htm#wp1805210
I hope this helps.
