Cisco VPN Client requires Internet access --- not "split-tunneled"
Jun 15th, 2007
I have an ASA 5510 appliance running 7.2 (ASDM 5.2) terminating Cisco VPN Client 4.8 users.
Everything works, meaning the Client can access corporate resources. However, due to "split-tunneling" being disabled (per corporate security policy) I will need to route all Internet-bound traffic through the appliance.
How is this done?
I have tried changing the tunnel default gateway to the 'inside' interface of the ASA. I have also added NAT entries for the VPN Client pools to be translated to a different IP Address on the 'outside' interface but it still does not work.
Thanks in advance.
--re
regraxpto Wed, 07/04/2007 - 15:56
Im not sure if there is any other way, but if you use a proxy in your internal network and configure it on the remote workers, it should do the trick.
Cheers,
Nuno
acomiskey Wed, 07/04/2007 - 17:32
  • Green, 3000 points or more
Sure this is possible. For example...
same-security-traffic permit intra-interface
ip local pool vpnpool 192.168.10.1-192.168.10.254
global (outside) 1 interface
nat (outside) 1 192.168.10.0 255.255.255.0
Here is the document that will also help if needed.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805734ae.shtml
Please rate helpful posts.
