4.1(3) SR5/5B - any experiences? " Requesting Template" problem.
Jun 15th, 2007
We have some 7960s with dual 7914s that are having a problem getting stuck in "requesting template" mode. Apparently SR5 is supposed to fix it. I see 4.1(3) SR5B is out. Anyone have experience with it?
gogasca Fri, 06/15/2007 - 11:12
Those phones are in remote locations?
If so what is the BW between those sites and any QoS fragmentation technique that you are using ? (ie FRF.12, MLPoFR...etc)
I experienced that issue in the lab with low BW in remote locations when FRF.12 Fragmentation was used.
bpalmquist Thu, 06/21/2007 - 09:19
Yes, they are remote/frame relay and have QoS, but no FRF.12.
I'm pretty sure the SR5 fix is going to take care of us.
bpalmquist Thu, 06/21/2007 - 09:20
Good to know. We're loading SR5B in a couple of weeks. In the meantime we've had no more "requesting template" issues and our fingers are crossed!
