qos preclassify command
Answered Question
Jun 15th, 2007
If doing QOS on a tunnel which is using IPSec, do you put the pre-classify command on the tunnel interface or in the policy map?
here's the config I've been given, and I notice that they've put it in 2 places.
Lisa Gcrypto map CRX0 10 ipsec-isakmp
description To ATL-CRX-7206A router
set peer 65.199.221.97
set transform-set TSI
match address CUSTNAME-ATLCRX
qos pre-classify
interface Tunnel1
description GRE Tunnel to Atlanta
ip address TUNNEL1_IPADDR_toATL 255.255.255.252
ip mtu 1440
qos pre-classify
Correct Answer by PAUL TRIVINO about 10 years 1 month ago
I don't know if you *need* it in both places but our configs *use* it in both places.
Paul
Overall Rating: 5 (1 ratings)
Correct Answer
PAUL TRIVINO Fri, 06/15/2007 - 15:42
  • Bronze, 100 points or more
Paul
