LDAP on 4400 setup troubles
Jun 15th, 2007
I want to setup a WLAN to authenticate through LDAP. I'm running 4.1.171.0 on the controller.
I setup the LDAP server (it pings, and believe base DN etc. is correct). I put LDAP first in the Auth Priority. I then setup a WLAN to have the LDAP server in the Security->AAA Servers list. Checked the 'Local EAP Authentication' and picked a Local EAP profile. My local EAP profile has EAP-FAST, EAP-TLS, Local Certificate, Client Certificate - all checked. The Issuer I kept Cisco.
That is all I see in the Configuration Guide for release 4.1 and I'm confused about the next step. How do I actually use LDAP? Following the above steps, I still have an unsecure WLAN that I can connect to without authenticating. I know it does not yet work for the Web Authentication. Do I (can I) use 802.1X? I am guessing that I need to turn on a Layer 2 or 3 security, but I'm at a loss.
Any help would be much appreciated.
Pat
drolemc Thu, 06/21/2007 - 06:16
  • Silver, 250 points or more
When you create a new WLAN, 802.1x is the default Layer 2 security mechanism. This setting forces a wireless client to first successfully authenticate by EAP before getting network access.
Trending Topics - Security & Network
