OWA behind CSS/SSL issue
Jun 15th, 2007
trying to setup OWA behind CSS with SSL termination.
http-header static "FRONT-END-HTTPS: on" is in place.
User can access folders and calendar, but can't see body of the messages
The problem seems to be that user at some point tries to use http instead of https,
and because frontend and backend rules have different IP addresses it is impossible
to access OWA via http directly from client.
Tried some other commands around http-header and urlrewrite, didn't work
Any help is appreciated
Overall Rating: 4.9 (5 ratings)
Syed Iftekhar Ahmed Fri, 06/15/2007 - 15:29
uses several other methods that are not recognized by default on the CSS so you will need
to add the functionality by running
css#script play setup_owa_methods
Gilles Dufour Sun, 06/17/2007 - 00:28
if the users tries to use HTTP at some point, there could be some 302 redirect in your owa server.
You might want to configure a urlrewrite function in order to convert from http to https.
But you should verify first if this is the case.
Try to sniff the client traffic and decode it with ssldump or wireshark using the server key.
a.gesse Sun, 06/17/2007 - 05:30
have tried it already.
Urlrewrite for "*" and explicitly defined frontend and backend ports as 443 and 80.
Sniffer showed 302 types redirects were coming with https.
Clients can see folders, calendar, subjects.
Can't see message bodies only.
Will start with clean config on Monday, what would you say is recommended list of commahds:
1. script play setup_owa_methods
2. static http-header "FRONTEND HTTPS=on"
3. urlerewrite ?
4. ?
Syed Iftekhar Ahmed Sun, 06/17/2007 - 15:35
You should have following two entries under SSL proxy list
ssl-server x http-header static "FRONT-END-HTTPS: ON?
ssl-server x urlrewrite 1 yourdomain.com sslport 443 clearport 80
Gilles Dufour Sun, 06/17/2007 - 22:11
get a sniff and see where the client request the body and if the server sends it.
Your config is fine. Nothing else is needed.
You may want to bypass the css and capture a sniff as well so you can compare the 2.
a.gesse Mon, 06/18/2007 - 09:18
Sorry for big post.
Still doesn't work - users see subjects, folder, calendar, don't see body.
ip route 1
!************************* INTERFACE *************************
interface e1
bridge vlan 131
interface e5
bridge vlan 130
interface e6
bridge vlan 130
!************************** CIRCUIT **************************
circuit VLAN131
ip address
circuit VLAN130
ip address
!*********************** SSL PROXY LIST ***********************
ssl-proxy-list Al#1-list
ssl-server 10
ssl-server 10 rsakey RSAKEYASS#1
ssl-server 10 rsacert RSACERTASS#1
ssl-server 10 vip address
ssl-server 10 cipher rsa-with-3des-ede-cbc-sha 80
ssl-server 10 cipher rsa-with-rc4-128-sha 80
ssl-server 10 cipher rsa-with-rc4-128-md5 80
ssl-server 10 urlrewrite 2
ssl-server 10 http-header static "FRONT-END-HTTPS: on"
!************************** SERVICE **************************
service OWA1
protocol tcp
port 80
ip address
keepalive uri "/adam.html"
keepalive type http
keepalive port 80
service ssl-mod
type ssl-accel
keepalive type none
add ssl-proxy-list Al#1-list
slot 2
!*************************** OWNER ***************************
owner OWA_OWA
content back.owa
add service OWA1
add service OWA2
advanced-balance sticky-srcip
protocol tcp
port 80
url "/*"
sticky-inact-timeout 240
vip address
content front.owa
vip address
protocol tcp
port 443
add service ssl-mod
~~~~~~Server answers to client with HTTPS (static header is working presumably):">
~~~~~ Some other stuff from server alse have HTTPS
height="16" id=idPageControl_PrevPage onclick="idMsgViewer.previousPage()" title="Previous Page"
id=idPageControl_NextPage onclick="idMsgViewer.nextPage()" title="Next Page"
width="16" height="16" id=idPageControl_LastPage onclick="idMsgViewer.page = -1"
~~~~~~ Client requests:
SEARCH /exchange/userone/Inbox/ HTTP/1.1
Accept: */*
translate: f
brief: t
Content-Type: text/xml
~~~~~~ Server responds with
HTTP/1.1 207 Multi-Status
Date: Mon, 18 Jun 2007 16:02:38 GMT
Server: Microsoft-IIS/6.0
X-Powered-By: ASP.NET
Accept-Ranges: rows
Content-Range: rows 0-5; total=6
MS-WebStorage: 6.5.7638
Transfer-Encoding: chunked
Cache-Control: no-cache
<?xml version="1.0"?>
xmlns:c="xml:" xmlns:a="DAV:">0-5
HTTP/1.1 200 OK< ~~~ (skipped)
~~~~~~~~~ And here I see HTTP instead of HTTPS (?) Something wrong ?
Gilles Dufour Tue, 06/19/2007 - 00:09
the urlrewrite function does not parse the http body. Only the header.
So, if the server sends http link in the body, that's what the client will see.
I'm not sure why the exchange server is doing this.
But what you can try to do is implement a http rule to redirect the traffic to https.
Try something like
service redirect
keepalive type none
ip address
type redirect
no prepend-http
owner OWA_OWA
content http_redirect
vip address
protocol tcp
port 80
add service redirect
Let me know if this works.
a.gesse Tue, 06/19/2007 - 08:33
Thanks Gilles, very much
It makes it work finally.
The question becomes is it the way how it is supposed to be,
because there still "http://" in the botom line during loading,
and these messages regarding secure/unsecure content mix.
Gilles Dufour Tue, 06/19/2007 - 21:44
yes, we had to adjust the config because the server sends http:// links.
Normally, with the "front-end-https: on" it's supposed to only send https link.
Maybe this is because by default the CSS only insert the header once.
You can try the following command to see if it makes a difference :
ssl-server http-header insert-per-request
I'm glad we finally have a solution.
Sniffer trace is always the best way to troubleshoot :-)
