Allow local,ld and a specific international country codes
Jun 15th, 2007
I have a hub and spoke voip network that is made of legacy PBX's connected to Cisco VOIP router and at the Hub is the same setup. I have been asked to provide a cheap voip service to the remote offices VONAGE router with a cisco dial peer connected back to the remote sites.I have configred the remote sites with dial-peer as below
dial-peer voice 2 voip
description Vonage test
destination-pattern 123T
session target ipv4:10.1.0.23
dtmf-relay h245-alphanumeric
playout-delay maximum 200
playout-delay nominal 100
playout-delay minimum low
codec g729r8 bytes 60
and at the Cisco Vonage gatway I have few FXO's with the below steup.dial-peer dial-peer voice 3848 pots
port 1/0/0
everything is working except they want me to allow country codes that are free to dial and deny the rest.
country codes 44 and 23 are allowed and the rest are denied. I am having hard time with this since all of my work on this has been resulted in allowing all international calls. Please I need your help on this.
Thanks in advance
