Integration between Cisco VOice gateway & Ericcsion MD110 EPBX
Jun 15th, 2007
Need to know what parameters needs to match in between Cisco VG & Ericcsion PBX while integration(india off is going to connect through MPLS link(E1) via VG to US, in US we have avaya PBX)
We have a E1 connection (trunk) between VG & PBX.
Also need physical connectivity details like cross or stratght cable details.
Send important doc link also
Naga.
paolo bevilacqua Sat, 06/16/2007 - 03:47
  • Hall of Fame,
    Founding Member
the pinout for the router is documented at at:
http://cisco.com/en/US/products/hw/modules/ps2641/products_module_installation_guide_chapter09186a008007cb4c.html
You will need to configure both PBXs for ISDN PRI as described at;
http://cisco.com/en/US/partner/products/ps6350/products_configuration_guide_chapter09186a00800ca716.html
Note the correct command is "isdn incoming-voice voice" and not "modem" as the documentetion wrong in this.
