have problem switch 6509
Jun 15th, 2007
Dear All,
I had switch cisco ws-c6509-E and have module ws-x6148A-GE-TX 48-port 10/100/1000 Base-TGE.On port g4/9 after i
shut down interface and no shut agian,it show message below:
HQ-6509(config-if)#int g4/9
HQ-6509(config-if)#shu
HQ-6509(config-if)#no shut
HQ-6509(config-if)#
00:44:03: %PM-SP-4-ERR_DISABLE: diagnostics error detected on Gi4/9, putting Gi4/9 in err-disable state
00:44:03: %PM-SP-STDBY-4-ERR_DISABLE: diagnostics error detected on Gi4/9, putting Gi4/9 in err-disable state
HQ-6509(config-if)#
what's going on?
Note:On port Gi4/9 connect to my pc,don't
link connection.
Best Regards,
join
mohammedmahmoud Sat, 06/16/2007 - 00:10
AFAIK there is a physical error on this port, as the diagnostics provide hardware-specific fault-detection.
HTH,
Mohammed Mahmoud.
join_sn09 Sat, 06/16/2007 - 01:47
Dear Mohammed ,
This problem,Can i fix it by myself?
Or need to send to factory?
Best Regards,
Join
