https stickiness with CSM
Jun 16th, 2007
hello,
i have the requirement to load balance https sessions via CSM. Can anyone advice how to maitain stickiness; since SSL headers will be encrypted, how will the CSM extract the cookies. If this will not work, any other way to do so?
thx
bassam
Overall Rating: 5 (1 ratings)
Gilles Dufour Sun, 06/17/2007 - 00:24
Bassam,
indeed the http info will be encrypted and so the CSM can't decode it and can't see the cookie.
You can use an ssl module to decrypt the traffic and send it back to the CSM.
Or you have to use the only alternative which is sticky based on source ip.
Gilles.
