i need a quick help plesae
Jun 16th, 2007
i keep getting these messages:
00:18:38: %AMDP2_FE-3-RXOVERFLO: FastEthernet0/1 Rx FIFO Overflow
00:18:43: %AMDP2_FE-3-RXOVERFLO: FastEthernet0/0 Rx FIFO Overflow
00:18:49: %AMDP2_FE-3-RXOVERFLO: FastEthernet0/0 Rx FIFO Overflow
00:18:55: %AMDP2_FE-3-RXOVERFLO: FastEthernet0/0 Rx FIFO Overflow
on a 2600 switch.
Paolo Bevilacqua Sat, 06/16/2007 - 04:11
  • Hall of Fame,
    Founding Member
IOS used ? Show interface for both FA, show what ?
Jon Marshall Sat, 06/16/2007 - 04:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Looks like you might be hitting a bug. From Cisco release notes
CSCdy78397
Symptoms Performance may degrade and the following message may be generated for heavily utilized Fast Ethernet interfaces on a Cisco 2600 series router:
"%AMDP2_FE-3-RXOVERFLO: FastEthernet0/1 Rx FIFO Overflow".
During the time this message is displayed, performance may unexpectedly degrade even further.
Conditions This symptom is observed on a Cisco 2600 series router that is running Cisco IOS Release 12.2(11)T.
Workaround Reduce traffic on the interface until the message is no longer not displayed
Try upgrading your IOS
Jon
