migration from PIX to ASA 5510
Jun 16th, 2007
i have a PIX 505 series, and i want to upgrade to ASA 5510 series. the IOS on the PIX is 7.2 version. do i copy and paste the CONFIG of the PIX into the ASA or i have to modify some rules in the CONFIG of the PIX ?
thanks
JORGE RODRIGUEZ Sat, 06/16/2007 - 05:37
  • Green, 3000 points or more
If they were the same exact model and code I would say yest but they are not. Even if the ASA5510 has the same code as the 505 they are not the same hardware platform. Take under consideration the physical interfaces, and any other configuration on the 505 to cary onto the 5510.
I would configure the ASA 5510 offline from scratch following the IP interface configuration, rules, nating etc.. specs from the 505.. load both PIXs using ASDM if nessesary to make the configuration easier on the new one, once fully configured come up with an implementation plan to swap the firewalls.
