Paolo Bevilacqua Sat, 06/16/2007 - 11:47
SDM can be confusing and produce non-working results, more importantly will prevent you from learning configuration. Tell us what you need to do with the router and we will point at examples or give tips.
royalblues Sun, 06/17/2007 - 02:17
I agree with Paolo on this.
Anyways i think the ISR routers get shipped ith the SDM. Can you see the sdm related files when you do a dir flash:
If you do not have SDM, then you may need to download the SDM related files on to your flash.
you can download them from
http://www.cisco.com/pcgi-bin/tablebuild.pl/sdm
more info about sdm on
www.cisco.com/go/sdm
http://www.cisco.com/en/US/products/sw/secursw/ps5318/prod_technical_reference_list.html
HTH, rate if it does
Narayan
