IOS advance Security
Jun 16th, 2007
I have purchase cisco 1841 routere with IOS advance security.I am using only IPsec.What is the other feature availabe in this IOS?does it supprot IPS,IDS,Firewalling etc ..Please help me.
dominic.caron Sun, 06/17/2007 - 05:19
Ability to Disable Xauth for Static IPsec Peers
Advanced Encryption Standard (AES)
Authentication Proxy Accounting for HTTP
Call Admission Control for IKE
Cisco Easy VPN Remote
CLNS Support for GRE Tunneling of IPv4 and IPv6
Connection-Mode Network Service (CMNS)
Context-Based Access Control (CBAC)
Crypto Conditional Debug Support
DES/3DES/AES VPN Encryption Module (AIM-VPN/BPII)
DF Bit Override Functionality with IPSec Tunnels
Distinguished Name Based Crypto Maps
Dynamic Multipoint VPN (DMVPN) Phase 1
Easy VPN Client RSA - Signature Support
Easy VPN Remote
Easy VPN Remote : Multiple Inside Interface Enhancements
Easy VPN Remote Enhancements
Easy VPN Remote Phase 4.1 Enhancements
Easy VPN Remote Web Based Activation
Easy VPN Remote: Local-Address Support
Easy VPN Remote: Manual Tunnel Control Enhancement
Easy VPN Server
EasyVPN Server Enhancements
Email Inspection Engine
Encrypted Pre-shared Key
Extended Simple Mail Transfer Protocol (ESMTP) for IOS Firewall
Firewall ACL Bypass
Firewall Authentication Proxy
Firewall Authentication Proxy for FTP and Telnet Sessions
Firewall Feature Set
Firewall Intrusion Detection System
Firewall N2H2 Support
Firewall Stateful Inspection of ICMP
Firewall Support for SIP
Firewall Support of Skinny Client Control Protocol (SCCP)
Firewall Support of SSL Encrypted HTTP Authentication Proxy Sign-on
Firewall Websense URL Filtering
Frame Relay Fragmentation with Hardware Compression
Frame Relay SVC Support (DTE)
Frame Relay Tunnel Switching
Granular Protocol Inspection
HTTP Inspection Engine
IDS Support of Security Device Event Exchange (SDEE)
IKE - Initiate Aggressive Mode
IKE Extended Authentication (Xauth)
IKE Mode Configuration
IKE Security Protocol
IKE Shared Secret Using AAA Server
Integrated IS-IS Global Default Metric
Integrated IS-IS Point to Point Adjacency over Broadcast Media
Integrated IS-IS Protocol Shutdown Support Maintaining Configuration Parameters
Intrusion Prevention System
Invalid Special Parameter Index (SPI) Recovery
IP Multilayer Switching (IP MLS)
IP over CLNS tunnel
IPSec and Quality of Service
IPSec Anti-Replay Window: Expanding and Disabling
IPSec Dead Peer Detection (DPD) Periodic Message Option
IPSec MIB Support for Cisco IPSec VPN Management
IPsec NAT Transparency
IPSec Network Security
IPSEC Preferred Peer
IPSec Triple DES Encryption (3DES)
IPSec VPN Accounting
IPSec VPN High Availability Enhancements
IPSec VTI - Virtual Tunnel Interface
IS-IS HMAC-MD5 Authentication
IS-IS Support for IP Route Tags
Large Scale Dialout (LSDO)
MTree crypto data structure optimizations
Multichassis MultiLink PPP (MMP)
NAC - Network Admission Control
NSF Awareness - IS-IS
OER Port and Protocol Based Prefix Learning
OER Support for Cost-Based Optimization and Traceroute Reporting
OER VPN IPsec/GRE Tunnel Optimization
Optimized Edge Routing (OER)
Option to Disable Hardware Crypto Engine Failover to Software Crypto Engine
Port to Application Mapping (PAM)
PPPoE Connection Throttling
PPPoE over VLANs Scaling and PPPoE over VLANs forwarding over PVC
PPPoE Service Selection
PPPoE Session Recovery After Reload
Pragmatic General Multicast (PGM)
Real-time Resolution for IPsec Tunnel Peer
Reliable Static Routing Back-up using Object Tracking
Response Time Reporter (RTR)
Response Time Reporter (RTR) enhancements
SRB - Source-Route bridging
Stack Group Bidding Protocol (SGBP)
Transparent IOS Firewall
Tunnel Endpoint Discovery
Virtual Templates for Protocol Translation
VRF Aware Cisco IOS Firewall
VRF aware IPsec
Wildcard Pre-Shared Key
+ IP SLA + Mobile IP
