%Error, "tftp://cme-gui-4.0.0.1.tar" is a directory.
Answered Question
Jun 16th, 2007
i am getting this error while extracting the .tar file to flash.
thx for consideration.
Correct Answer by paolo bevilacqua about 10 years 1 month ago
there is a bug with these symptoms, CSCek63178. However is not clear if it has been fixed. Try extracting te file on another router and then copy them manually.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Sun, 06/17/2007 - 03:32
  • Hall of Fame,
    Founding Member
paolo bevilacqua Sun, 06/17/2007 - 05:21
  • Hall of Fame,
    Founding Member
Absolutely. And the bug says "no workaround" ?!?
C'mon cisco, you can do better than that!
Thanks for the nice rating and good luck!
