Newbie ASA 5505 Configuring for internet PPPoE ?
Jun 17th, 2007
Hi all expert
I am very newbie for this Firewall and have never done any Cisco security course, so please bear with me.
Currently we have a Pix 501 that works well, now we upgrade to ASA 5505, and I have been trying to get internet connection for a week now but no go at all .
Any help would be much appreciated.
Here is our network:
Internet -> DSL Negear Modem -> ASA 5505 -> inside network
And here is "show run" :
ciscoasa(config)# show run
: Saved
ASA Version 7.2(2)
hostname ciscoasa
enable password xxx
interface Vlan1
nameif inside
security-level 100
ip address
interface Vlan2
nameif outside
security-level 0
pppoe client vpdn group pppoe_group
ip address pppoe setroute
interface Vlan3
no forward interface Vlan1
nameif dmz
security-level 50
no ip address
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
dns server-group DefaultDNS
access-list inside_access_out extended permit ip any interface outside
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit tcp any any
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
ip verify reverse-path interface outside
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1
access-group inside_access_in in interface inside
**** inside IP schema:
route inside 1
route outside 61.9.x.x 61.9.a.b 1
route outside 144.140.x.x 61.9.a.b 1
**** 61.9.a.b is static IP provided by ISP
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
**** I issued CLI command to get vpdn rather than ASDM
vpdn group pppoe_group request dialout pppoe
vpdn group pppoe_group localname vb39033
vpdn group pppoe_group ppp authentication chap
vpdn username vb39033 password *********
dhcpd ping_timeout 750
dhcpd address inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
: end
Overall Rating: 4 (1 ratings)
cal060307 Sun, 06/17/2007 - 06:26
Thanks for your reply and link
That link helped me configure PPPoE client rather than ASDM but still no connection
In regards to VLAN interface, by default ASA has two VLANS one for outside and one for inside.
JBDanford2002 Sun, 06/17/2007 - 07:04
Have you tried removing the vlan interface and configuring the physical? Also have you tried debugging pppoe to see if there are any errors?
debug pppoe error
cal060307 Sun, 06/17/2007 - 17:34
No I have not tried remove VLAN yet. I am not quite confident to remove the default setting, as I am newbie just in case
However I issued "debug pppoe error" command line, nothing happens.
I issued "show ip address outside pppoe"
PPPoE assigned IP address: 61.9.a.b interface: outside
Remote IP address: 172.18.y.z
Fernando_Meza Sun, 06/17/2007 - 19:31
Hi .. if you already have an IP address allocated to the outside interface then your connection to your ISP is fine. Test this by pinging any public IP from your ASA. By looking at your config, it seems you are intending to use the inside interface of the ASA as DHCP server correct ..? if that is the case then you need to ENABLE dhcp on the inside interface and add an auto-config commands which will also provide your internal devices with DNS settings. Below is an example.
hostname(config)# dhcpd address inside
hostname(config)# dhcpd autoconfig outside
hostname(config)# dhcpd enable inside
NOTE: this line of config does not make much sense ..
route inside 1
I hope it helps .. please rate it if it does !!!
cal060307 Mon, 06/18/2007 - 02:46
Thanks for your help
DHCP: I was going to do it but I'd rather use my existing DHCP server, so I think I should I take it out.
route inside 1
That line I just copy and paste from working Pix 501 in use. Yes you are right it does not make sense to me either.
I will trying ping outside public IP say to see if it gets thru, I doubt very much otherwise I would get internet connection by now. Thanks again
cal060307 Tue, 06/19/2007 - 21:42
Hi all
Question please:
Do we need to have any access-list to allow traffic inside to flow outside in order to get internet access? or any thing else after establishing PPPoE client through Wizard.
Thank you in advance
cal060307 Wed, 06/20/2007 - 17:47
Hi all
I got this problem solved, what I did was that I got back the factory default and restart PPPoE client without any access-list.
Thanks a lot for your support and help guys.
