2 7815 servers capacity
Jun 17th, 2007
i have a question on capacity of of 7815 MCS
as known 7815 supports up to 300 users, if i have two 7815 servers CCM1 (pub) and CCM2 (sub) is it poosible to configure 2 callmanager groups CCM-Group1 has only CCM1 callmanager in its list and CCM-Group2 has only CCM2 in its list, so this way my servers can support up to 600 users? 300 users with device pool 1 that contains CCM-Group1 and the other 300 users with device pool 2 that contains CCM-Group2?
i know there is no redundancy if doing so, but my question is about capacity?
thanks
Overall Rating: 3 (1 ratings)
Rob Huffman Sun, 06/17/2007 - 05:21
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi U-C,
As you have said, this isn't really a recommended design. That being said, you can configure the Callmanager Groups/Device Pools exactly as you noted.The other thing that Cisco notes in their SRND docs is to avoid having phones registered to the Publisher if possible, but, as we all know sometimes fianancial considerations come in to play here.
So yes, technically speaking, this could be done.
Hope this helps!
Rob
