Jun 17th, 2007
Dear Gentlemen,
1 - What is the Antenna which give me the same coverage of (2.2 dBi Dipole Antenna,2.4 GHz) Prod. # AIR-ANT 4941
2 - If i want to change the current antennas, should I make a new site survey
3 - I need url for Multi floor Site Surve ?
Overall Rating: 3 (1 ratings)
jwadleigh Fri, 08/24/2007 - 12:51
1.) In general, the gain and beamwidth of an antenna dictates the shape of the coverage. That being said, each antenna has its own propagation characteristics. The best thing to do is buy another 2.2dBi omnidirectional and lab it up.
2.) Was your original site survey conducted using the 2.2dBi dipoles, or was it strictly predictive? If the survey was done with real world data from your old antennae, then coverage may be quite different with new hardware. My suggestion would be to do a new survey.
3.) A URL? You mean which company should you use?
