WebVPN using VPNC
Jun 17th, 2007
Our client is having an issue while accessing webvpn using SSL VPN client, the message prompt...
"The SSL VPN Client was unable to successfully verify the IP forwarding table modifications. An SSL VPN connection will not be established."
Any idea? TIA.
Overall Rating: 4.5 (2 ratings)
guibarati Tue, 06/19/2007 - 06:23
  • Bronze, 100 points or more
Did you created the VPN through WEB VPN wizard on SDM? is it a router?
enkrypter Wed, 07/18/2007 - 07:57
On an ASA you can get this message if you configure a Split Tunnel ACL as an extended ACL with protocol and port constraints.
Split tunnel ACL's are typicly standard, you would then use the vpn-filter and an extended ACL to restrict the traffic.
