506e slow internet access
Answered Question
New to 506e. Just installed. Replaced a Netgear FVS318. Cable for the internet connection. Pix 6.3(4) PDM 3.0(2). Internet is now doing a whooping 222k. Where should I start looking?
Correct Answer by JBDanford2002 about 9 years 7 months ago
Looks like you possibly have a bad cable or a duplex mismatch. Are you hard coding the interface? (speed/duplex)
Overall Rating: 5 (1 ratings)
JBDanford2002 Sun, 06/17/2007 - 09:39
First I would look at your interfaces for errors. Post a copy of your "sh int".
Here it is:
Result of firewall command: "sh int"
interface ethernet0 "outside" is up, line protocol is up
Hardware is i82559 ethernet, address is 0013.60ac.bc3d
IP address 24.166.106.239, subnet mask 255.255.254.0
MTU 1500 bytes, BW 100000 Kbit full duplex
262124 packets input, 110396808 bytes, 0 no buffer
Received 184612 broadcasts, 51 runts, 0 giants
5921 input errors, 2796 CRC, 3074 frame, 0 overrun, 2796 ignored, 0 abort
55770 packets output, 6130659 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (128/128) software (0/49)
output queue (curr/max blocks): hardware (0/3) software (0/1)
interface ethernet1 "inside" is up, line protocol is up
Hardware is i82559 ethernet, address is 0013.60ac.bc3e
IP address 192.168.0.254, subnet mask 255.255.255.0
88463 packets input, 8799641 bytes, 0 no buffer
Received 10697 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
102423 packets output, 110751550 bytes, 0 underruns
input queue (curr/max blocks): hardware (128/128) software (0/15)
output queue (curr/max blocks): hardware (5/41) software (0/1)
Lots of errors on the WAN port
Correct Answer
JBDanford2002 Sun, 06/17/2007 - 10:19
