Jun 17th, 2007
hi guys, i have 2 questions plz tell me
1) wat benefit i can get by changing the value of transmit-delay from 1 to something else ???
2) is there any possible way of preferring inter-area routes over intra-area ?? i checked ospf faq and it said that we cant but we can do it also by changing the ospf process, my question is can i do it without changing the process ???
plz tell me
thanks in advance
Richard Burts Sun, 06/17/2007 - 18:47
As for OSPF I do not believe that there is any way to get OSPF to prefer an inter-area route over an intra-area route. I am not clear what kind of change you could make in the OSPF process that would do this.
shaila_rox Sun, 06/17/2007 - 23:44
hmm ok but wat abt the transmit-delay question ?? wat possible benefit can i get by changing its default value ??
plz tell me this also
smothuku Mon, 06/18/2007 - 03:25
Hi ,
To set the estimated time required to send a link-state update packet on the interface, use the ip ospf transmit-delay .
1 second
Usage Guidelines
Link-state advertisements (LSAs) in the update packet must have their ages incremented by the amount specified in the seconds argument before transmission. The value assigned should take into account the transmission and propagation delays for the interface.
If the delay is not added before transmission over a link, the time in which the LSA propagates over the link is not considered.
****** This setting has more significance on very low-speed links.
The following example sets the retransmit delay value to 3 seconds:
interface ethernet 0
ip ospf transmit-delay 3
Hope it clarifies your dought...
