dealing with switch 2900 IP addressing
Jun 17th, 2007
the problem is that I have a switch 2900 xl seires and I can not make a telnet to it
in my network the management vlan is vlan no 6 so i had to assign ip address to the interface vlan 6 on that switch
I did that but it remained shut down despite being manually configured to be up
when I use interface vlan 1 it responded but the telnet yet didn't work
i need a suggestion
rajinikanth Sun, 06/17/2007 - 22:46
  • Bronze, 100 points or more
Have you configured your VTY lines with password and login commands.
VTY LINES are needed to be configured for telnet connection
Raj
wamohamed Sun, 06/17/2007 - 22:56
Hi Raj,
yes ofcourse i configured vty lines and set the password but the problem still exists
i think that the problem is related to the fact that i set interface vlan 1 as the management interface whereas it should be interface vlan 6 which i can not configure on that switch
mohammedmahmoud Sun, 06/17/2007 - 23:18
  • Green, 3000 points or more
You must be connected to the switch on a port in VLAN6.
HTH,
Mohammed Mahmoud.
glen.grant Mon, 06/18/2007 - 04:19
  • Purple, 4500 points or more
If you have a management vlan and also have other different vlans assigned to this switch your uplink has to be a trunk link in order to do this . Also the 2900 has to be a newer 8 meg box versus the old 4 meg 2924's which would not support trunking.
