IP Sec tunnel over mutillink interface
Jun 17th, 2007
I am trying to build one IPSec tunnel where i am using the Multilink interface as a source on my end router.
But i am unable to build this tunnel up.
Now i have doubt like whether we can build IPSec tunnel on multilink or not?
If we can configure the IPSec with multilink then please share your suggestions. If anyone have same sample configuration, Please share with me.
Thanks in advance.
Ajeet
sundar.palaniappan Mon, 06/18/2007 - 16:59
  • Green, 3000 points or more
Ajeet,
I see no reason why you can't use multilink interface as the source address to form an IPSEC connection. By default IPSEC connection terminates on the egress interface and if multilink isn't the egress interface then configure the command "crypto map (name) local-address multilink(#)" from the global config mode.
If you are still having issues please provide us a copy of the sanitized configuration.
Sundar
