call recording software
Jun 18th, 2007
i wish to know how can we use some third party call recording softwsre to record calls and what will be the configuration on ccme.currently i am using ccme4.0 on 2800 router.
thx for reply...
Overall Rating: 3 (1 ratings)
Paolo Bevilacqua Mon, 06/18/2007 - 01:15
there are many third-party software to do this. if you search in the forum, you will find a thread with the names, and I have even more names.
No configuration on the CCME is necessary. The software works by capturing signaling an voice streams from a span port on the switch.
