CSM-S SSL certs: can 2 SSL certs be used for the same server farm?
Answered Question
Jun 18th, 2007
Can 2 SSL certs be used for the same server farm? I?ll put it in context:
We have a web site on win2003 IIS6 ? this is replicated on 8 identical servers for the farm. The web site will respond to *.test.uk and *.test.com over SSL. This means the CSM-S must respond with the correct SSL cert for the same farm.
Correct Answer by Gilles Dufour about 9 years 7 months ago
yes, you can reuse the same serverfarm for both site.
But, you need to have different vserver for each cert. So a different ip or a different port.
Gilles.
Overall Rating: 4.5 (2 ratings)
Correct Answer
Gilles Dufour Mon, 06/18/2007 - 07:06
Gilles.
