no-xauth, no-config-mode
Answered Question
Jun 18th, 2007
What is the meaning of [no-xauth, no-config-mode]?
Disable VPN Software connection if run [no-xauth, no-config-mode]?
Correct Answer by shomar about 9 years 8 months ago
no-xauth is used the extended authentication, that is to have the user prompted for a user name and password before connecting
no-config-mode is used to disable pushing data to the user connecting through the VPN client like the ip address, the DNS server, WINS server ....
both of the above are mandatory to exist when connecting using a software VPN client.
I hope that the above answers your questions.
Kindest regards,
Shadi`
Overall Rating: 5 (1 ratings)
Correct Answer
shomar Tue, 06/19/2007 - 00:13
Kindest regards,
Shadi`
logintck Tue, 06/19/2007 - 00:40
If I would like make connection through VPN client, how I can do it?
shomar Tue, 06/19/2007 - 02:18
By default, Xauth and config mode are enabled for VPN traffic, which means that you don't have to enable it.
usually disabling this traffic is done for site to site VPN tunnels.
following is a configuration example for configuring PIX and VPN client, I hope it would be helpful :)
http://www.cisco.com/en/US/partner/products/sw/secursw/ps2308/products_configuration_example09186a00801e71c0.shtml
K.Regards,
Shadi`
