You can create MOH Server for each CM server that has "Cisco IP Voice Media Streaming App" service enabled.
Then create another MRG referencing the second MOH server, and add it to the MRGL.
If you are using MOH Multicast you will need to assign different IP address or Port Number (depending on which method you use) for the second MOH server.
HTH,
Chris
