Launch External Application question
Jun 18th, 2007
Howdy. I would like to have my Agents have Remedy (our Helpdesk application) launch when they start their CAD. Does Remedy need to be installed on the CRS server in order to be able to do that?
We are using 4.0.4 (or 4.0.3) Premium.
Overall Rating: 4 (1 ratings)
lpezj Mon, 06/18/2007 - 03:56
You don't need to install Remedy on CRS Server. You only have to install Remedy on your agents desktops and launch Remedy when CAD starts.
To do this you have to set up an action that opens Remedy when CAD launches from the Cisco Desktop Administrator.
Hope this helps,
Juan Luis
juwaack68 Mon, 06/18/2007 - 04:02
Thanks for the reply Juan Luis!
Went to class last week after supporting IPCC since last August (i.e., it was dumped on me) and found out about this forum there - I love forums!!
So, just to confirm, I should be able to have the path of "C:\Program Files\AR System\User\aruser.exe" (minus the quotes) in the 'Application' field and it will follow that path on the Agent's desktop?
lpezj Mon, 06/18/2007 - 04:06
I think that it is enough. I have made some demos using the simple 'notepad' and works.
Hope this helps,
Juan Luis
(Please, rate helpful posts ;-))
