SYSTEM INIT: INSUFFICIENT MEMORY TO BOOT THE IMAGE!
Answered Question
Jun 18th, 2007
i keep getting this error on boot, though i have the ip base image. it worked before, than someone played with it and it stoped.
can someone help?
the configuration is attached.
Correct Answer by Edison Ortiz about 10 years 1 month ago
You have enough memory (256MB) and the software only requires 128MB. It seems the IOS is corrupted. You must reinstall a clean copy on flash and try again.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Mon, 06/18/2007 - 06:04
  • Hall of Fame,
    Founding Member
modragon Wed, 06/27/2007 - 05:58
I have the same problem with my 3550. It worked fine for a few weeks then one day I got the INSUFFICIENT MEMORY TO BOOT THE IMAGE
Were you able to reload the image and get it working?
blacktulip Wed, 06/27/2007 - 21:31
yes, i reloaded the image with tftp, it erased the flash, and now it's working fine.
