loadbalancing on 2M leased line
Jun 18th, 2007
hi
i have two 2M leased lines running from one of my remote offices to HQ,i want to
1 try to loadshare traffic between the two links
2 loadbalance traffic between the two links
the routing protocol used is EIGRP
either one of the two solutions will be accepted.
Edison Ortiz Mon, 06/18/2007 - 06:14
  • Hall of Fame,
    Founding Member
EIGRP will load balance the traffic for you, by default. If you want to share the traffic equally, you can enable cef and under each interface enable per-packet load sharing.
Keep in mind, per-packet load sharing can introduce new problems since packets may arrive to the destination out-of-order. VoIP traffic is one kind of traffic that would be affected by this configuration.
