06-18-2007 05:46 AM - edited 03-14-2019 10:08 PM
Anyone know if it is possible to setup automatic calling with call manager express?
for example, extension 300 with a user id of user1 lifts there handset and the phone automatically calls extension 301 without any intervention?
Cheers
Chris
06-22-2007 06:09 AM
enable the connection plar (private line automated ringer) command under the voice port.
06-23-2007 12:58 AM
thanks for the response.
but this is an ip phone not an anaologue.
Only 8 of the ip phones will need this feature whilst the remaing to operate normally,
Can connection plar be used for ip phones ?
06-23-2007 02:27 AM
If I understand correct you have an IP Phone that whenever you if the handset you want to dial a predefined number all the time.
Under the ephone-dn, use the trunk command with the destination number.
e.g.
ephone-dn 3
number 1001
trunk 1002
When you lift the handset on extension 1001 it will automaticlly dial 1002.
Cheers,
Mike.
Plse rate helpful posts.
06-23-2007 02:46 AM
hi,
thanks for that, will try it next week and let you know
