MGCP Gateway Problem
Jun 18th, 2007
Hi all,
voice-port 0/2/0
voice-port 0/2/1
ccm-manager mgcp
mgcp
mgcp call-agent 10.3.1.196 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp validate domain-name
mgcp profile default
dial-peer voice 100 voip
destination-pattern ....
session target ipv4:10.3.1.196
dial-peer voice 1000 pots
service mgcpapp
port 0/2/0
Above is my configuration of mgcp gateway with VIC2-2FXO... its registered with CCM and was working fine...all of a sudden it stopped working.... when I dial on the number terminated on FXO, call dont go through.... I have attached a file with sh ccm-manager and debug mgcp events output.... Any help ??
Sheeraz
sheerazkhatri Fri, 06/22/2007 - 22:03
CCM 4.1(2)...and the voice gateway is 2811.
Here is the show version as well .
KHI-FTC-RO-I-A8M1-02#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.3(14)T
7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 22-Mar-06 18:40 by pwade
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
KHI-FTC-RO-I-A8M1-02 uptime is 3 days, 17 hours, 10 minutes
System restarted at 17:53:53 GMT Tue Jun 19 2007
System image file is "flash:c2800nm-adventerprisek9-mz.123-14.T7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2811 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FHK0918F098
2 FastEthernet interfaces
62 Serial interfaces
2 Channelized E1/PRI ports
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62592K bytes of ATA CompactFlash (Read/Write)
Any suggestion.Thanx in advance
Sheeraz
