Jitter 10ms
Jun 18th, 2007
What is an acceptable Jitter Rate for an SLA with a service provider?
MY provider is saying that they will guarantee that jitter will not go
above 10 milliseconds and it will be measured in 5 minute intervals.
This is an MPLS network and we will run IP voice over this network.
What amount of Jitter can cause voice communication problems? Is it 8
milliseconds?
Thank You for any responses, all responses are greatly appreciated.
Have a wonderful day.
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Mon, 06/18/2007 - 09:24
That depends also by the endpoints you are using. eg the cisco router and telephones can tolerate jitter also of 20 - 30 msec quite well.
blatkinson Mon, 06/18/2007 - 09:44
If you know your jitter will be consistent and low, you can set a static jitter buffer on the endpoints. Cisco says their dynamic jitter buffers are good at adjusting the buffer but if you know your jitter limits already you can go with a static buffer as the dynamic buffer is always going to add a little "wiggle room" so it can adapt just in case there is a deviation from the trend.
Here are a few references that can help you:
http://www.futurehardware.in/339875.htm
http://www.ciscopress.com/articles/article.asp?p=606583&seqNum=2
Please rate if this helps.
