FWSM - delete access-list
Jun 18th, 2007
I recently upgraded our FWSM from 2.3 to 3.1
Previously if I wanted to make multiple changes to an access list I would edit it offline and then re-upload after using the "no access-list WHATEVER" command to delete the old version.
However this command is not available on 3.1 - how then can I delete an access-list??
OK the newer image does allow you to use line-numbers to edit ACLs but this is no substitute for being able to edit offline. Any ideas?
liamkennedy Mon, 06/18/2007 - 07:48
ok - found it. its "clear configure access-list WHATEVER"
not that this is particularly obvious from the configuration guide or the command reference (indeed the troubleshooting section of the conf guide specifically says to use "no access-list")
