unable to connect to internet from 10.100.1.x and 10.100.2.x
Jun 18th, 2007
I recently migrated our firewall from pix 6.3 to asa 5510. After the migration only the users having ip address 10.100.0.x can connect to the internet except the others having the IP address 10.100.1.x and 10.100.2.x. Everything else works fine as before. I copied most of the config including nat and accesslist from the previous config. What could be possible causes of this problem?
acomiskey Mon, 06/18/2007 - 09:02
Could you post a clean config? Possible cause could be a /24 mask instead of /16 mask in your nat statement etc.
acomiskey Mon, 06/18/2007 - 09:16
You may also need a route inside for the .1 and .2 networks?
kcarjun2002 Mon, 06/18/2007 - 11:57
Thanks all for the response. I found that net mask for inside interface was set up as 255.255.255.0 (/24) All of the internal servers have ip address 10.100.0.x/16. Most of the clients get ip addresses 10.100.1.x/16 from dhcp server.
Do you think netmask /24 for inside interface is the problem.
