You can either call into your mailbox and press * or setup a DID number and translate this number to your Unity hunt pilot using a translation pattern. You can also enter your mobile number as an alternate extension so when you dial the external number, you are only prompted for your PIN.
Hope this helps. If so, please rate the post.
Brandon
