2610 Factory Reset and Startup Config Files
Jun 18th, 2007
Hi all;
I have a used 2610 which I did a factory reset on. I am able to get into the IOS and edit/change the config.
However after editing and trying to save using the command:
copy run start
I get prompted to save the config to a file name/location which ultimately fails. Then on reboot it goes into the "basic setup" sequence again never saving to the config I'm trying to save.
The IOS ver. is 12.0(3)T and I do have the latest ver. and an TFTP program to upgrade, but I would like to create a config and save it first.
Thanks in advance. Steve
Edison Ortiz Mon, 06/18/2007 - 10:12
  • Hall of Fame,
    Founding Member
Have you checked the config-register ?
Please post the output from typing 'show ver'.
schroednet Mon, 06/18/2007 - 18:57
Edison;
Thanks for the reply. Yes my register was 0x2142 but I did the "config-register 0x2102" and then was able to copy the running config to the startup config.
I do have another ?. I did type in a time offset command for my timezone but after reboot it keeps defaulting back to year 1993.
Here's my sh ver:
IOS (tm) C2600 Software (C2600-I-M), Version 12.0(3)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Mon 22-Feb-99 20:00 by ccai
Image text-base: 0x80008088, data-base: 0x8069353C
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
uptime is 14 minutes
System restarted by reload
System image file is "flash:c2600-i-mz.120-3.T"
cisco 2610 (MPC860) processor (revision 0x202) with 18432K/6144K bytes of memory
Processor board ID JAB03090910 (856765012)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Thanks, Steve
mohammedmahmoud Mon, 06/18/2007 - 22:45
  • Green, 3000 points or more
Unfortunately the clock settings are cleared at router reboot, you can configure a NTP server to overcome this issue.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
