Switchport Access VLAN 123
Jun 18th, 2007
All, what happens if a port is configured as:
interface GigabitEthernet1/0/21
switchport access vlan 100
spanning-tree portfast
but does not have switchport mode access?
is the switchport mode access command needed?
Edison Ortiz Mon, 06/18/2007 - 09:54
  • Hall of Fame,
    Founding Member
If you connect another switch on this port, it may trunk if you don't set the switchport mode access.
By entering the switchport mode access, you are forcing the port to only use access mode.
You can view the current switchport mode by typing:
show int g1/0/21 switchport
rwamstutz Mon, 06/18/2007 - 10:02
so it really doesnt hurt anything by not having the command, but without it, if someone were to plug a switch into that port, it would go into trunking mode?
Edison Ortiz Mon, 06/18/2007 - 10:05
  • Hall of Fame,
    Founding Member
It may go into trunking mode, yes.
In a secure environment, it's always recommended to enter the switchport mode access command.
Can you post the 'show int g1/0/21 switchport' output ?
rwamstutz Mon, 06/18/2007 - 10:12
This is the output on a port without the switchport mode access command:
BOSTON#sh int g4/0/12 switchport
Switchport: Enabled
Administrative Mode: dynamic auto
Operational Mode: static access
Administrative Trunking Encapsulation: negotiate
Operational Trunking Encapsulation: native
Negotiation of Trunking: On
Access Mode VLAN: 101 (VLAN0101)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Edison Ortiz Mon, 06/18/2007 - 11:31
  • Hall of Fame,
    Founding Member
As you can see:
Switchport: Enabled
_____________
Administrative mode is set to dynamic auto, if you connect a switch with dynamic mode desirable, it will form a trunk. A switch with dynamic mode auto, won't form a trunk. So, it depends on the type of switch you connect here.
Currently, the port is running:
because that's what it sensed from the workstation connection.
You should be fine under this config but I wanted to point out, the 'what if' ..
