Duplicate user in ACS 3.3 database
Answered Question
Jun 18th, 2007
I am using ACS to authenticate mac addresses. This is on an appliance. I created a user with the user name and password as the mac address and now it is listed twice! I can delete one entry but not the other. What can I do to clear this out of the database?
Correct Answer by Jagdeep Gambhir about 10 years 1 week ago
Hi ,
Please use the dbcompact command via the serial console to fix it.
Here is the link for steps for running dbcompact.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacsapp/csa
pp33/install/admap.htm#wp1058379
That should fix it.
Jagdeep
Overall Rating: 5 (1 ratings)
jlhainy Mon, 06/18/2007 - 13:41
Awesome, that did the trick! Thank you much.
